I am using custom action type 50 to launch an exe in the source dir. In the custom action table the Source is set to a key in the property table which holds the string "[SourceDir]MyExe.exe" and in the Target i was passing parameters [EDITA1][EDITA2].
When i run the msi and click on the button its giving an error that a program is reuqired.
If im hotcoding the [SourceDir] path its working well. I had set the standard action ResolveSource after CostInitialize action in the InstallExecuteSequence table, but even then it was unable to resolve the [SourceDir] in the value column of the property table.
But i was able to see [SourceDir] path when i assign it to a Edit control.
Can anyone please help me in this or if any of you guys have a sample of how to launch an exe from sourcedir please send me.
Thank you very much in advance
Hemanth Kumar Gunnam
hemanthyours@gmail.com
Launch exe in the SourceDir on click of a button
hemanthyours
, May 15 2008 15:21
Posted 19 May 2008 - 19:39
For a type 50 custom action, the Source column must be the name of a property (without []) and that property must contain the full path to the executable file. So you could add a type 51 action to assemble the path and store it in a property, and reference this property in the Source column.
