Hello!
I have a Log.Rul script file, which I included into the Setup.Rul file to log/document the setup process. Now, I want to use the logging functions within my Dialog.Rul und SetupFunction.Rul file also. If I include it within these files too, I get "already defined" errors.
How can I uses functions within multiple Rul files?
Thanks in advance,
Thomas
Btw, I use InstallShield 2012 with a InstallScript project.
Can I include Rul files twice?
ThomasM
, Oct 10 2012 09:24
Posted 10 October 2012 - 12:39
You don't need to include an RUL file twice to achieve this common logging support.
Instead, just include the Log.Rul script in your main Setup.rul file along with the other Dialog.Rul & SetupFunction.Rul files and the compiler will be able to resolve things okay.
Posted 10 October 2012 - 14:55
You may need to put (only) the prototype in a .h file and include that in the other .ruls
Posted 12 October 2012 - 10:26
Thanks Stefan, Thanks Taco Bell.
Unfortunately, neither including the Log.Rul file in Setup.Rul and calling the WriteLog() function from SetupFunctions.Rul, nor putting the prototype to a Log.h file worked.
I always get the error: WriteLog : identifier already defined
I guess I have to reduce logging to the Setup.Rul file actions.
Regards,
Thomas
Regards,
Thomas
Edited by ThomasM, 12 October 2012 - 10:27.
Posted 12 October 2012 - 15:27
So you only have the function in one .rul file, and this .rul file is not #included anywhere, and the prototype is in the .h file and the .h file is included in all .rul files, and you still get that error message?
