How to reate an hyperlink?
Posted 07 June 2001 - 09:39
I want, for example, to put www.mycompagny.com.
Urgent.
Posted 07 August 2001 - 10:14
For example, create a text file called InstallShield.url with :
[InternetShortcut]
URL=http://www.installshield.com
You can then place this file in a component and link a dektop shortcut to it as usual. I got this answer from the installshield newsgroup which I have found to be very useful.
(And since a .url file is an INI file, you could presumably use the INI File
Changes view or InstallScript INI functions to modify its contents, if need
be.)
Posted 14 August 2001 - 18:22
Posted 14 August 2001 - 18:44
If you really need a hyperlink control you must create a dll with that dialog (and the code to handle it) and call it from a custom action.
