Our product (v3.0) was deployed using WISE for Windows Installer v5.2 and uses MSI 2.0 as its runtime. We decided not to go with v6.0 of WfWI and instead bought InstallShield X for future use.
We're making the installer for v4.0 in ISX of our product which is still under development and this release uses some COM components that are shared with v3.0, we've got the two products installed (and both work fine) inside some VM's for Win2k and WinXP (others will tbe tested later), however removing v4.0 (based on ISX) removes those files required by v3.0 (based on WfWI) and application breaks unless we "repair" the installation.
Is there a guideline out there that specifies how to manage such situations? Should we instead stick with WfWI and just rewrite the installer for v4.0 of our product in that instead of ISX?
PS. Go easy on me, i'm no installer guru
