I created Registry Sets and assigned them to components when they were getting installed that it should write to the registry. Currently, it's only writing to software/.../Version
I have 5 different registry sets and it writes to them fine, but after a few minutes all of the registry values get sent to the first registry set I created.
So..
Registry Set 1
../Software/.../Set1Version
Registry Set 2
../Software/.../Set2Version
Registry Set 3
../Software/.../Set3Version
After a few minutes, it turns into
Registry Set 1
With the other two Registry Sets empty
What gives?
Feature specific registry
AcidJazz
, Dec 11 2006 23:46
Posted 12 December 2006 - 11:18
Does this happen in your project file? And it doesn't happen immediately but only if you wait (without doing anything) for a few minutes?
Posted 12 December 2006 - 16:29
Yeah in the ISM file it is not working either. I guess I could edit it manually, but I find it weird that it does that...
I am trying to use variable values and folder names in the registry (ie. [MAX_VERSION]) and am not sure where to set these. I went to properties under install script and had functions brought up to edit their values. I figure changing their values pre install (ie OnBegin handler) will be sufficient but I haven't tested it yet.
If that's not supported in InstallScript projects, that could be another reason its broken. I know it works in MSI projects but their property tables are literally tables and not functions you have to declare pre install.
Thanks for replying
Thanks for replying
