Hello,
I apologize if this posting is in the wrong place but based on my limited knowledge this seemed like a good start.
I have MathCad 14 installed on my machine. It was downloaded as an evaluation. Since then the evaluation has lapsed and I would like to remove it from my computer.
Unfortunately, when I try to uninstall it through "Add/Remove Programs" it hangs up mid way and freezes.
Can someone point me to a diagnostic or other procedure whereby I can figure out what is causing this problem? OR, can someone tell me how I can manually remove the software from my computer?
Thanks in advance for any replies.
Jason
MathCad 14 (PTC) Uninstall / Install Hang
kb5urq
, Oct 01 2008 15:32
Posted 01 October 2008 - 16:31
- Start RegEdit
- Browse to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall
- There will be a series of keys in GUID format. Browse these keys, checking out the 'DisplayName' value until you see the one relating to MathCAD.
- Further down that right-hand pane will be a value 'UninstallString'.
- Copy the value's data to the clipboard
- Paste the clipboard contents into a command window, adding the 'verbose log' argument. Let's say the product code is '{14061E15-C0E1-456B-9280-0D6D347164D2}' then the UninstallString will look like this:
...MSIEXEC /i{14061E15-C0E1-456B-9280-0D6D347164D2}
- Change it to:
...MSIEXEC /i{14061E15-C0E1-456B-9280-0D6D347164D2} /QB /L*V %TEMP%\MyUninstall.log
in order to mimic as closely as possible the behaviour of ARP.
- When you believe that the install has hung, monitor the file size of %TEMP%\MyUninstall.log to see whether or not the Windows Installer engine is writing data to it. If you're sure it isn't and that the install has hung, open that file (use a decent text editor, not NotePad!). You may have to kill the MSIExec processes (yes, plural) as some editors see a file hook as a file lock.
You should now be able to see where in the uninstallation process the log file stopped and work from there.
Also, you may want to use a file/registry/process monitor (like ProcMon) to monitor the process interactively. Note that that will slow things down a little, though.
- Change it to:
