Is there a direct way to drive IS 5.5 builds using a batch file? Has anyone tried adapting a batch file created using 6.x and making that work in a 5.5 environment? Weighing the alternatives ... thanks. - Alex
Export (Build) Batch File...
ajenkins
, Jan 05 2005 01:18
Posted 06 January 2005 - 16:12
if you have compile.exe and build.exe in your program folder, you can run them from a batch file ...
: Save the current search path Set SavePath=%Path% : Set the search path to find InstallShield's command line tools Path "%ISHIELD%\Program";%Path% set INCLUDE=%include_dir% : Execute the command line compiler compile setup.rul -i"%INCLUDE%" > ISBuild.rpt :: Test for success. Quit if there was a compiler error.if errorlevel 1 goto CompilerErrorOccurred isbuild -m"%media_name%" -p"%folder%" -b"%output%" >> ISBuild.rpt :: Test for success. Quit if there was a build error. if errorlevel 1 goto BuildErrorOccurred :CompilerErrorOccurred echo echo echo echo. ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿ echo. ³ ³ echo. ³ Compile error ³ echo. ³ Media not updated ... ³ echo. ³ ³ echo. ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ Pause press any key to view the compile report type ISBuild.rpt | more Goto _exit : Report the build error; then exit :BuildErrorOccurred echo echo echo echo. ÚÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄ¿ echo. ³ ³ echo. ³ Build error. ³ echo. ³ Media not updated ... ³ echo. ³ ³ echo. ÀÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÙ Pause press any key to view the build report Type ISBuild.rpt | More :_exit Path=%SavePath% Set SavePath= del isbuild.rpt /q |
Edited by Perotin, 06 January 2005 - 16:13.
Gruß / regards
Thomas
Thomas
