I've been having problems attempting to install different components to different directories. Basically, I'm installing my core files to INSTALLDIR and I want to install some other files/directories to ORACLEDIR (which is defined through some scripts in the wizard) However, when I have the compenents and features defined with ORACLEDIR, they don't install - anywhere. If I set them to install into INSTALLDIR, they install just fine. Any thoughts?
(BTW - I'm using ISWI 2.03a)
Thanks!
Installing different compements into different dir
brianw
, Mar 22 2002 20:49
Posted 25 March 2002 - 10:26
How and where are you defining ORACLEDIR?
You want to define it initially in the directory table. The . means it is intially equivalent to INSTALLDIR.
eg.
Directory: ORACLEDIR
Directory_Parent: INSTALLDIR
DefaultDir: .
Your script can reset it to another value with MsiSetTargetPath after costing.
eg.
DefaultDir: .
Ian Blake
(Currently Unemployed)
