Thanks very much for your help
install SQLDMO
Augusto
, Feb 04 2002 15:50
Posted 04 February 2002 - 15:50
I need to browse MSDE instances on the network and display the findings on a combo box. To do so, I need to have SQLDMO installed on the target machine. I have had problems doing so, when starting an msi installation from a CA during the UI. Is there any way to from the setup.exe launch an msi before the main one (if certain condition is met)
Posted 18 February 2002 - 09:39
I added the CA that launches a second msi before displaying any of my dialogs before CostFinalize (that its triggered on the NExt button of one of my Dialogs). The install returns an error when I run it.
Posted 07 March 2002 - 00:21
As an alternative to DMO, I avoided the DMO installation issue by using the WNet functions to enumerate the servers on the network and then used ServerGetInfo() to retrieve the server types. The server type contains a flag for SQL servers. The only issue with this is that it doesn't find SQL servers running on Win95 machines. For some reason the flag isn't set in their server type information.
