Hello all,
Has anybody ever been able to install an NDIS intermediate driver with DIFxAPP? I've been trying to do this, unsuccessfuly so far... I have a small msi, with the DIFxAPP.msm module merged in. I add the .sys and the two .inf files. I enable the Windows installer logging. Then, when I run the msi I get all sorts of errors from DIFXAPP:
- if I leave the components' destinations for the two .inf files the same, DIFxAPP complains about "multiple driver packages"
- if each .inf component has its own destination, I get a error 0x52, failure to add driver package to driver store.
- I read somewhere that 0x52 may be caused by a failed signature verification, so I enabled debugging on my machine (XP Pro, SP2) and set the _DFX_INSTALL_UNSIGNED_DRIVER environment variable to 1; I get the same error.
Any pointers/suggestions appreciated!
TIA
DIFxAPP with NDIS intermediate driver
dmaftei
, May 08 2006 18:33
Posted 15 May 2006 - 08:18
I don't know about an environment variable but the Flags column of the "MsiDriverPackages" table does have a flag you need to set:
const DriverLegacy = 8 ;;Default requires driver to be signed
When you moved the INF, I assume you updated them to point to the new .SYS path (or you moved the .sys files as well)...
Bye,
Dennis Bareis
Bye,
Dennis Bareis
Dennis Bareis (dbareis@No.Spam.gmail.com)
Free MSI update/creation tool (MAKEMSI):
http://users.cyberon...eis/makemsi.htm
