In documentation for RemoveExistingProducts Action I find next sequence restriction:
AntonS
, Aug 20 2004 12:06
Posted 20 August 2004 - 12:06
| The RemoveExistingProducts action must be scheduled in the action sequence in one of the following locations: … Between the InstallExecute action, or the InstallExecuteAgain action, and the InstallFinalize action. Generally the last three actions are scheduled right after one another: InstallExecute, RemoveExistingProducts, and InstallFinalize. In this case the updated files are installed first and then the old files are removed. However, if the removal of the old application fails, then the installer rolls back both the removal of the old application and the install of the new application. |
According to this, I place actions in InstallExecute sequence next order:
InstallExecute
FindRelatedProducts
I encounter with an error at install time.
Here is the part of verbose log:
| Action start 13:28:44: FindRelatedProducts. Action ended 13:28:44: FindRelatedProducts. Return value 1. Action start 13:28:44: RemoveExistingProducts. DEBUG: Error 2613: RemoveExistingProducts action sequenced incorrectly. Internal Error 2613. Action ended 13:28:44: RemoveExistingProducts. Return value 3. |
Where I can place FindRelatedProducts and RemoveExistingProducts actions?
Posted 20 August 2004 - 12:54
Try and validate your MSi to see if that brings up additional information.
