I'm attempting to call LookupPrivilegeValue from the ADVAPI32 library. The first two parameters of the call are strings, no problem there. The third parameter is a pointer to a LUID, which is a 64-bit identifier.
Does anyone have any suggestions as to how I pass the LUID? InstallShield numbers are only 32-bit.
If possible, I'd like to avoid the use of a C++ dll.
Thanks for any suggestions.
64 bit return value in InstallScript
Leigh Ravenhall
, May 28 2002 08:51
