Hello,
I recently came across a MSI which had upgrade table entries as follows:
Column Value
UpgradeCode <Upgrade Code>
VersionMin Blank or null
VersionMax Blank or null
Language Blank or null
Attributes 0(This value is not documented on MSDN)
Remove Blank or null
ActionProperty <Some GUID> (This is valid as the GUID has all uppercase characters)
From reading the MSDN documentation, it is very clear that both VersionMin and VersionMax columns cannot be null. However, in this case , both the columns had null values.
There is no documented behavior for an attribute value of 0. However, the attribute column had a value of 0 for this entry.
Inspite of all the above, the msi was able to perform a successful major upgrade.
Can anyone explain this strange behavior?
Kiran Hegde
Upgrade table - - Strange behavior of the msi
kirann_hegde
, Apr 23 2012 07:59
Posted 24 April 2012 - 08:49
0 for Attributes is okay. It means that none of the flags is set.
VersinMin and VersionMax both blank is not allowed per documentation, which means that the result is undetermined. It might uninstall any version (as it seems the case here), it might not uninstall any version, or it might crash.
ActionProperty must be a valid property name (not a GUID). It may contain characters, digits, underscores or periods. But no curly braces {} or hypens. So a GUID is not a valid property name (and it would also be quite confusing).
