I have a component with a key file that is used to create an advertised shortcut. If I move or delete this file then when I launch IE6, I get a Windows Installer window. It tries to reinstall my component but cannot find the MSI package.
I will use key path in the registry instead of key files, is this correct or is there a better way to avoid this problem.
David
