Hi, everyone. I don't know where to post this question, so I post it here. I tried to use the PackageForTheWeb to package two sequential setups. However, when it runs, after it finishes running the first setup, at the beginning of the second setup, it removes both the Data1.cab file for the first setup and the one for the second setup at the temp folder. Does anyone know what causes this? What can I do so that the Data1.cab file for the second setup will not be removed at the beginning of the second installation? Any suggestion is welcome. Thank you.
John
PackageForTheWeb packages two setups
JohnWu
, Nov 16 2004 18:42
Posted 18 November 2004 - 09:29
How did you tell PFTW to run two setups? I think you can only specify one executable to be launched, or?
