I've got a legacy product that I've packed up using WinInstall LE, which all [seems] to work fine.
However in this application I have the need to copy two files which I prepared earlier, into a specific location in the installation incorporating the computer name (%COMPUTERNAME%).
To clarify using the following batch command on a computer called 'ORAC'
copy c:\temp\filename_ c:\temp\filename_%COMPUTERNAME%
Would have the desired effect, leaving a file called 'c:\temp\filename_ORAC'
I've had a look at the MoveFile table and read through the SDK stuff about MoveFiles as an action, but it doesn't quite fit. I want the installer to put the files in place for me, then move them to the new name. But Movefiles is run before Installfiles and the Movefile locations seem to be restricted to a finite list.
I haven't really started expermenting with this yet, I was hoping that someone out there could save me the time.
Am I going to have to create a Custom action for this seemingly simple activity?
Regards,
Adrian.
Copying files to new names.
adrianw
, Jun 02 2003 23:22
