Does anyone know why the installer tries to resolve directories which are NOT targeted (is this a bug?), and if it does so, is there any workround or defensive programming that can be used?
Problems with Directory Table
Posted 20 November 2001 - 12:49
Posted 23 November 2001 - 15:14
Posted 23 November 2001 - 17:31
Also all directories listed in the target machine's PATH environment variable should exist and be accessible.
Posted 26 November 2001 - 11:39
It's also commonplace, esp with laptops,. to refer to drives which "don't exist" when they are not connected to a network. Admittedly, in my experience, (I do a lot of work from home - where I may or may not be connected to a second network), this simple fact seems to have escaped Microsoft - maybe it doesn't happen in the States? - but for years I've had to find all kinds of workrounds due to the fact that sometimes I'm connected directly to a network, sometimes by phone, and often not at all. Even with WIN2000, Windows frequently hangs when using Outlook or IE if I'm not very careful with connections.
So I don't really see how this solves the problem, though I'm currently trying to narrow down the conditions under which it occurs.
Posted 26 November 2001 - 13:30
I cannot reproduce the problem under WIN2000. However cunningly I try to point the shell folders at non-existent /disconnected/shared then unshared drives, the system always returns them to their orignal value - at least, after trying an install, there they are back again. So this may be a WIN98 problem only (which was what our user was on).
this is complicated by the fact that I am now running installer vsn 2.0, whereas the user was running 1.2, and at the moment I don't have access to a WIN98 machine with 1.2 installer due to people being on holiday.
Interestingly, the (failed) log file reports MSI © (29:61): "Found shell folder G:\My Pictures by spelunking through the registry." - but then fails at CostFinalize when it cannot resolve a directory reference to g: Does this mean anything to you?
Posted 26 November 2001 - 16:13
I can't remember to have ever seen "spelunking through the registry" in a MSI log file.
Posted 20 March 2002 - 00:40
I noticed your post regarding WIS Error 2103: unable to resolve path to shell folder. I know it was a few months ago but I was wondering if you had made any progress. I'm getting this error also and I don't think that it's related to the erroneous entries in the directory table either. I can reproduce the error on any msi repackaged or otherwise--including good old Orca.msi.
We have a windows 2000 group policy which redirects the 'My Documents' folder to a network location. This folder redirection policy is using the %USERNAME% variable and points to \\server\share\%USERNAME%. It doesn't appear to matter whether the network location is accessible or not, the msi always fails.
Definitely seems like a bug to me.
Any help is greatly appreciated.
Dan Lawrence
p.s. Here's a bit of the verbose log:
_
MSI (s) (98:C8): Found shell folder by spelunking through the registry.
MSI (s) (98:C8): Note: 1: 2103 2: 26
DEBUG: Error 2103: Could not resolve path for shell folder 26.
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2103. The arguments are: 26, ,
MSI (s) (98:C8): Product: Orca -- The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2103. The arguments are: 26, ,
_
