When using InstallShield 6.3 to install software, I get an error during both the installation and un-installation processes. A message box appears with the title 'Advanced Inf Installer' with a message of 'Error Loading setupapi.dll'. This is repeated a number of times, usually when trying to install msxml3 components. Has anyone encountered this problem before and is there a solution?
ARobinson.
setupapi.dll
arobinson_uk
, Mar 04 2002 17:59
Posted 04 March 2002 - 21:50
I'm using my own custom Component/FileGroup .... basically a self-registering file group containing msxml3.dll and a non-self-registering one containing msxml3a.dll and msxml3r.dll. The actual message appears around 7 times on install and even more frequently on uninstall.
Posted 04 March 2002 - 23:47
Yeah, I have a manual XML3 component of my own, so I'm aware of the process. However, are you certain that XML is the reason for your errors?
Either way, two things to try:
1. Move the msxml3.dll file to the non-reg. file group and instead manually register in your script.
2. Switch to batch self. reg. mode via
Enable(SELFREGISTERBATCH);
The reason for each of these approaches is that the supporting DLLs must be present BEFORE the main file can be properly registered. The default registration approach does NOT ensure this since its done as they are copied.
