After merging msm file into msi package (with Orca) there is an error message (while installing) ".. file cannot be found in cabinet file". When I set "extract cabinet file" option in Orca merge dialog I see successfully extracted cab with required file inside. What does it mean?
Merging module - installation fault
igodunov
, Jan 30 2006 14:15
Posted 31 January 2006 - 07:50
This error means that your install is trying to install a file that is not located inside the CAB file. Run an ORCA validate to see if you can find out whats missing.
Maybe the name of the file is incorrect?
Posted 31 January 2006 - 10:56
I was mistaken when decided that merge action updates target package with msm cab file. Actually, I have to use ExtractCAB method to extract cab from msm
then write this cab into _Streams table of the target package.
