Avoid downgrade
cornel_gav
, Apr 01 2008 12:58
8 replies to this topic
Posted 01 April 2008 - 12:58
I want to disaply a MessageBox informing the user that he's making a downgrade and stop the installation.
How can I do this in InstallShield?
Posted 01 April 2008 - 13:47
It depends on whether you are changing the ProductCode (Major or Minor Upgrade)
Posted 02 April 2008 - 13:47
Add a row to the Upgrade table to detect the downgrade, with the "detect only" flag set. Add a type 19 (display error message and exit) custom action to both the UI and the Execute sequence. Use the property from the Upgrade table as condition for the custom action.
Posted 05 April 2008 - 06:29
With Installshield 2008 there are now built in Installshield support for this via a default Upgrade table entry and a custom action called ISPreventDowngrade in both sequences.
Posted 05 April 2008 - 23:34
That's true, if you are using InstallShield you don't need to do this manually. However (if I recall correctly) IS 2008 will not add this to projects you migrate from previous InstallShield versions, only for projects you create in IS 2008 from scratch.
Posted 29 May 2008 - 10:17
It looks like Installshield will add this custom action whenever the Upgrade table is authored - even for older projects.
Posted 29 May 2008 - 11:28
The Upgrade table entry created looks like this:
UpgradeCode: {00000000-0000-0000-0000-000000000000}
VersionMin: ***ALL_VERSIONS***
VersionMax:
Language:
Attributes: 2
Remove:
ActionProperty: ISFOUNDNEWERPRODUCTVERSION
ISDisplayName: ISPreventDowngrade
Anyone know what's up with the GUID and the MinVersion fields. Are these undocumented Microsoft MSI features or some Installshield franken-beast?
VersionMax:
Language:
Attributes: 2
Remove:
Posted 30 May 2008 - 11:57
I believe these are placeholders which get replaced with the actual UpgradeCode and current version number during build. You should only see them in the project file but not in the built msi file.
