On my windows 2000 machine, everything works fine. However, when the same installer is run on the XP machine, no registry entry is made at
HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\<PRODUCT_GUID>
subsequently, the program does not appear in the Add/Remove applet.
Does anyone know why this is? I have changed the DISK1DIR variable, but it should still works. Afterall, it does on 2000.
thanks
Uninstall Registry Missing
SoSaucily
, Aug 28 2002 20:31
Posted 28 August 2002 - 21:57
And you are using IS 6.31 in order to properly support Windows XP, right? You also have Windows XP as a valid OS in the project settings, right?
Posted 28 August 2002 - 22:13
You assume too much. Actually i had 6.30 and am currently upgrading. Thank you
Posted 29 August 2002 - 02:06
No, I wouldn't say I assume too much. If I had I wouldn't have asked those initial questions.
