I want to run ISD8 standalone compiler (IsSaBld.exe) where it generates "One Cab per Component" like you can specify when using the Release Wizzard.
I see no way to specify this (either on the command line or with an .ini file). Any tips appreciated.
Dale
IsSaBld.exe "One Cab per Component" ?
daleq
, Jan 29 2003 02:12
Posted 29 January 2003 - 18:04
You can't do this in ISD8
If you create a .ini file to "feed" IsSaBld.exe, you can specify a line like
;Configuration=COMP -c Compressed vs. uncompressed.
Configuration=COMP
You also can not use the automation interface to the standalone build to get my desired behaviour.
I just _love_ how InstallShield advertises a new feature that sounds great and then when you go to actually USE it, you find that it's implemented in a half-baked manner.
Dale
Configuration=COMP
Dale
Posted 14 February 2003 - 23:13
You can work around this problem by setting the custom compression in your Release and then calling that Release with the -r switch.
