Hi Guys,
I'm creating un MSI. The first step is to Know if the .NET Framework SP1 is installed or not.
I thing I must finding for a registry key, is that true?
can you help my ?
thanks
Attilia
.NET Framework
Attilias
, May 12 2003 17:26
Posted 16 May 2003 - 21:36
You can check the file version of:
%SYSTEM32%\mscoree.dll
or Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\Product\Microsoft .NET Framework Full v1.0.3705 (1033)
or Registry Key
Posted 24 June 2003 - 14:31
For version 1.1 see here
http://msdn.microsof...stdeploy1_1.asp
I hope microsoft mantain the same standard for future versions of the framework...
Posted 24 June 2003 - 15:54
In case you need to check this as a LaunchCondition in your msi, you can check the property MsiNetAssemblySupport
