Does anyone know how to read the .MSI file from inside a single-file install (setup.exe) created with Installshield? I can open the setup.exe with WinRAR, which reports it as "SFX CAB archive", but the only files I can see seem to be the msi runtimes, not the actual .MSI file or the files that are to be installed...
Extract MSI file from setup.exe
Posted 23 January 2002 - 07:29
Posted 23 January 2002 - 18:50
Posted 24 January 2002 - 00:37
Posted 24 January 2002 - 15:51
(you may need to specify the full path to your.msi)
Posted 25 January 2002 - 10:55
Posted 30 January 2002 - 18:24
I would have tried Setup.exe /V"/a"
Hope this helps.
JSP
Posted 30 January 2002 - 23:34
When I try setup /a, it does (sort of) work, but asks the user for a destination path. I was after an automatic way of doing it - preferably "silent" (no UI).
Posted 31 January 2002 - 10:52
If this is the case, it works. And if you want to perform it in blind, try: setup.exe /s /V"/a /q"
If you are not in compressed mode, just launch msiexec with the command line parameters that are described in the documentation.
JSP
Posted 31 January 2002 - 11:08
The setup.exe is one that contains the entire setup package compressed in it... It was created with ISWI 2.0
Posted 31 January 2002 - 11:15
Posted 03 February 2002 - 08:56
If you use the /a option with msiexec (instead of InstallShield's setup.exe) you should specify the path to the msi file.
