Hello,
I am a newbie to Installshield application. I am trying to create a new package for a certain applicaton of mine..As part of it, I need to add three constant lines at the end of a windows text document present in a certain directory.
Lets say the document (..\system32\etc\folders\services.txt) is always present here...Thru installshied, I need to open this services.txt and append three lines at the end of this document. Lets say the three lines are:
Line1 Input11 Port 1111
Line2 Output11 Port 1112
Line3 Error11 Port 1113
How do I go about updating this through installshield scripts...
Kamur
file update
kamur
, Jun 12 2003 05:20
Posted 15 June 2003 - 09:27
This is pretty simple to do. The code would go something like the following:
NOTE: I didn't compile this code, but it should be close to syntactically correct. Also, you should have better error checking/handling in your actual code like testing the individual WriteLine results, but this will at least get you going.
By the way, welcome to InstallShield.
| NUMBER nResult, nvFileHandle; STRING szPath, szFilename; szPath = <Specifies the path (which may include a drive designation), of the file you want to open.> szFilename <Specifies the unqualified name (that is, without a drive designation or path ) of the file you want to open.> nResult = OpenFileMode(FILE_MODE_APPEND); nResult = OpenFile(nvFileHandle, szPath, szFileName); if (nResult = 0) then nResult = WriteLine(nvFileHandle, "Input11 Port 1111"); nResult = WriteLine(nvFileHandle, "Output11 Port 1112"); nResult = WriteLine(nvFileHandle, "Error11 Port 1113"); nResult = CloseFile(nvFileHandle); else MessageBox("Unable to open the file '"+szPath^szFilename"'.", WARNING); endif; |
Edited by TacoBell00, 15 June 2003 - 09:30.
