Hello, I want to remove maintenance mode all together and just run the normal install to overwrite the previous installation. Can someone help?
Thanks!
~Chris
Do not want users to access maintenance mode
newport
, Sep 23 2002 16:00
6 replies to this topic
Posted 23 September 2002 - 16:07
I don't know if that's such a good idea. I would be highly upset if I loaded something onto my system that would not uninstall. I don't want to lecture, but maybe you should rethink your ideas on this one.
Posted 23 September 2002 - 17:47
Xitch13: Removing Maintenance mode doesn't mean you can't uninstall the product. One still maintains an Add/Remove Program entry to accomplish that. The main purpose is such that if you re-run the setup a 2nd time, you get the same dialogs that you would the 1st time.
Newport: For what it's worth, you'd already gotten that same answer in your previous post on the subject.
Posted 23 September 2002 - 17:54
I realize that, but the topic's subtitle was "...just reinstall, never remove". That's what I was worried about.
Posted 24 September 2002 - 16:59
My fault on that one! I just wanted to prevent maint mode when running setup.exe.. I wanted the program to be removed from add/remove in the control panel, which that artical showed me how to do.. Sorry for the confusion.
~Chris
~Chris
