Now, double-clicking on a ".frm" does not work for NT only. The only change made was to lengthen the command needed to open this ".frm" file.
When I look in My Computer/View/Folder Options/File Types and look at the open command for NT, it is blank. In Windows 98 & 2000, it has the long command needed to double-click on the file. The command is 170 charaters long.
When I try and paste the command here by hand after the install, it seems to take the entire command initially, but when I go back into the file types area, it has chopped the file at 130 characters.
Has anyone run across this. I suspect this may be a Windows NT issue since the install works for Win98 & 2000.
Thanks for any thoughts you might have on this.
