I have been using Installshield 2008 in which i ve been using "Installscript" Project. when I try to place the splash screen under "Support Files/Billboard --> Splash Screen --> English(United States)" window named as "Setup.bmp" splashscreen is not popping up.
Dimensions of my splash screen is 510*281 , size 420KB
Setup.gif also didn't work.
Also tried in Language Independent window.
Any Help would be greatly appreciated.
Splash screen fails to popup
Essien
, Dec 12 2007 15:06
Posted 20 December 2007 - 20:27
Put it in the 'Language Independent' folder instead, unless you explicitly need to separate English/non-English splash screens.
Posted 15 January 2008 - 20:29
I'm having the same problem and I've put it under Language Independent.
BMP size - ~300kb - Setup.bmp as required. Also, .gif doesn't show.
Any suggestions?
thanks
Any suggestions?
thanks
Posted 11 March 2008 - 14:09
I had the same issue until I reduced the image to 24k instead of full colour. InstallShield was able to render it then.
Cheers,
ME
Cheers,
ME
Mark
Mitel Networks Corporation
mitel.com
