Is there a way that I can write to the msi log file from a custom action, or do I need to create my own? The custom action calls an API in a dll.
Anthony
Writing to the log file
anthonyh
, Mar 05 2002 19:23
Posted 05 March 2002 - 19:23
Product Availability Developer
Avantis
Invensys Process Systems
Using InstallShield Developer 7.04 - Basic Project
Avantis
Posted 06 March 2002 - 05:02
I use MsiProcessMessage(hInstall, INSTALLMESSAGE_INFO, hMessageRecord).
Create hMessageRecord using MsiCreateRecord, and set field 0 to the text you want in your message. If you want to make it display Installer propertes, just use the standard [property] syntax. Also, [1] takes the value in field 1, etc.
Jamie
The geek shall inherit the earth
Posted 06 March 2002 - 16:26
For MsiCreateRecord(), what do I pass in as the parameter, 1?
Thanks.
Thanks.
Avantis
Avantis
Posted 12 March 2002 - 02:35
The parameter you pass in to MsiCreateRecord is the number of extra bits of information you want displayed in your message. The following example will make a log file line with 2 parameters.
This will create the following line in the log file:
You can also use MsiCreateRecord(0) to create a log line with no extra parameters. Eg:
| Code Sample |
| UINT Function1(MSIHANDLE hInstall) { PMSIHANDLE hMessage = MsiCreateRecord(2); MsiRecordSetString(hMessage, 0, "Field 1 is '[1]'; Field 2 is '[2]'"); MsiRecordSetString(hMessage, 1, "I am field 1!"); MsiRecordSetInteger(hMessage, 2, 1234); MsiProcessMessage(hInstall, INSTALLMESSAGE_INFO, hMessage); } |
| Code Sample |
| Field 1 is 'I am field 1!'; Field 2 is '1234' |
| Code Sample |
| UINT Function2(MSIHANDLE hInstall) { PMSIHANDLE hMessage = MsiCreateRecord(0); MsiRecordSetString(hMessage, 0, "Starting installation of [ProductName] [ProductVersion]"); MsiProcessMessage(hInstall, INSTALLMESSAGE_INFO, hMessage); } |
Jamie
