I want to install a database application. I want that during the installation the user can select between two possible databases and the installer copy this DB to a specific dir. How can I make that?
custom copy
amg_soft
, Dec 16 2003 19:43
Posted 22 December 2003 - 20:42
Place each database file(s) in separate Components. In the IDE, Setup types tab view, un-check the yellow folders that correspond to these two components. Use an IS form to allow the user to select between these two databases (Components). Then use ComponentSelectItem ( MEDIA , DATABASE_A_COMPONENT ,
TRUE ); to set the selected component to TRUE. Good coding practice says that you should also set the unselected Component to FALSE.
