I have a dialog in my Install script type of Installer where the user has the option to specify installation for 'single user (this computer only)' or 'All users on this computer'.
When i run this installer on Windows vista (as Standard User) by selecting install only for 'single user', and when i log in as an local admin on that vista machine, i will still be able to open the application.
Ideally the install should have happen only for that Standard User.
Please suggest.
vamshi
Single user (per user) installation in Vista
brvamshi
, Jun 29 2007 00:09
Posted 03 July 2007 - 12:26
How do you open that application as administrator? Do you see a shortcut in the start menu or do you double click the exe file?
Posted 03 July 2007 - 20:06
When i log in as the Admin/any other user, the application shortcut appears in the Start Menu->Programs-"App Name".
When i click on the shortcut, it opens the application.
When i install the application as a Standard user, it creates registry keys in the HKCU\Software\"App Name"
When i log in as a Admin User, i can still see the registry entries in the HKCU\Software\"App Name" which ideally should not be the case.
Not sure, what is going on. Any pointers please?
Thanks.
Thanks.
Posted 05 July 2007 - 19:24
Open that start menu folder in Explorer (by right clicking in the start menu). There's one for the current user and one for all users. In which of them is the shortcut?
HKCU is only for one user. If you install for user A and then log in as user B I find it hard to believe that the entries exists in user B's HKCU hive. That hive isn't even loaded during the installation. This could only happen in HKCR because part of this is mapped to HKLM.
