i would just like to know on where could i find a documentation in this one....
To successfully run a custom action that is run from an installed file, you must ensure that the file is installed locally using a conditional statement:
If the custom action is sequenced before RemoveFiles—Run the action only if the component was installed locally.
(?ComponentName=3)
If the custom action is sequenced between RemoveFiles and InstallFiles—Run the action only if the component was installed locally. Do not run the action on an uninstallaton.
(?ComponentName=3) AND NOT($ComponentName=2)
If the custom action is sequenced after InstallFiles—Run the action only if the component will be installed locally.
($ComponentName=3)
The ComponentName is the component where is associated with the source file.
it seems that i could not find it in the installshield help.
Are this true?
(?ComponentName=3)
($ComponentName=3)
coz im using (&ComponentName=3) rather than ($ComponentName=3)
Install Exec Condition
haroldxious
, Jan 29 2007 07:40
Posted 30 January 2007 - 09:41
For components, only $ and ? are valid prefixes. & and ! are used for features. See Conditional Statement Syntax in the SDK.
