When I look at the properties for a Shortcut the Feature property is DISABLED and set to 'Always Install' even though I also have 'Additional Info'.
WHY, and HOW do I FIX the problem?
Are Feature dependent Shortcuts possible?
rhmorrison
, Feb 20 2004 15:58
Posted 24 February 2004 - 10:03
This one I found the answer to myself.
The FEATURE is disabled because the particular files that were being used for the shortcut were only a member of one particular feature and therfore it is not necessary (nor possible) to select the feature.
I ASSUME that if one file is contained in more than one feature that it is then possible to select to what feature the shortcut is connected to.
Robert H. Morrison
"Luke, use the source"
