Kleine Korrektur zum Beitrag oben:
Wenn ich "Build Patch" ausführe steht im Ausgabefenster immer "MINOR upgrade" auch wenn es nur ein SMALL upgrade ist. Das scheint demnach nicht der Fehler zu sein.
Hier ein Auszug aus dem Log-File:
MSI (s) (68:D4) [10:18:09:318]: SOFTWARE RESTRICTION POLICY: Verifying patch --> 'C:\Users\Desktop\UpdatePatch2.msp' against software restriction policy
MSI (s) (68:D4) [10:18:09:318]: SOFTWARE RESTRICTION POLICY: C:\Users\Desktop\UpdatePatch2.msp has a digital signature
MSI (s) (68:D4) [10:18:10:193]: SOFTWARE RESTRICTION POLICY: C:\Users\Desktop\UpdatePatch2.msp is permitted to run at the 'unrestricted' authorization level.
MSI (s) (68:D4) [10:18:10:193]: SequencePatches starts. Product code: {ACE3D0E1-5DD4-4C6D-A9E7-50AE71E35C68}, Product version: 14.0.00.0, Upgrade code: {0A2C392F-2DEC-49E3-A7C2-342B637766D6}, Product language 1031
MSI (s) (68:D4) [10:18:10:193]: PATCH SEQUENCER: verifying the applicability of minor upgrade patch {B818F6C0-B69A-44A8-8321-5F6F9335ADAC} against product code: {ACE3D0E1-5DD4-4C6D-A9E7-50AE71E35C68}, product version: 14.0.00.0, product language 1031 and upgrade code: {0A2C392F-2DEC-49E3-A7C2-342B637766D6}
MSI (s) (68:D4) [10:18:10:240]: PATCH SEQUENCER: minor upgrade patch {B818F6C0-B69A-44A8-8321-5F6F9335ADAC} is applicable.
MSI (s) (68:D4) [10:18:10:240]: PATCH SEQUENCER: verifying the applicability of minor upgrade patch C:\Users\Desktop\UpdatePatch2.msp against product code: {ACE3D0E1-5DD4-4C6D-A9E7-50AE71E35C68}, product version: 14.0.01.0, product language 1031 and upgrade code: {0A2C392F-2DEC-49E3-A7C2-342B637766D6}
MSI (s) (68:D4) [10:18:10:240]: Note: 1: 2253 2: 3: MsiPatchOldAssemblyName
MSI (s) (68:D4) [10:18:10:240]: PATCH SEQUENCER ERROR: failed to retrieve the upgrade code AU1ToAU2 transform in C:\Users\Desktop\UpdatePatch2.msp patch takes the product to! (1: 2253 2: 3: MsiPatchOldAssemblyName )
MSI (s) (68:D4) [10:18:10:240]: PATCH SEQUENCER: minor upgrade patch C:\Users\Desktop\UpdatePatch2.msp is not applicable.
MSI (s) (68:D4) [10:18:10:240]: SequencePatches returns error 1627.
MSI (s) (68:D4) [10:18:10:271]: Produkt: RTM Version 2014 - Update "{FF6C16B5-7B6B-4FA7-A967-B7A88B2244D7}" konnte nicht installiert werden. Fehlercode 1603. Weitere Informationen sind in der Protokolldatei c:\AU14020.log enthalten.
MSI (s) (68:D4) [10:18:10:271]: Ein Update wurde durch Windows Installer installiert. Produktname: RTM Version 2014. Produktversion: 14.0.00.0. Produktsprache: 1031. Hersteller: Firmenname AG. Updatename: {FF6C16B5-7B6B-4FA7-A967-B7A88B2244D7}. Erfolg- bzw. Fehlerstatus der Installation: 1603.
MSI (s) (68:D4) [10:18:10:271]: Note: 1: 1708
MSI (s) (68:D4) [10:18:10:271]: Produkt: RTM Version 2014 -- Installation fehlgeschlagen.
MSI (s) (68:D4) [10:18:10:271]: Das Produkt wurde durch Windows Installer installiert. Produktname: RTM Version 2014. Produktversion: 14.0.00.0. Produktsprache: 1031. Hersteller: Firmenname AG. Erfolg- bzw. Fehlerstatus der Installation: 1603.
MSI (s) (68:D4) [10:18:10:271]: Attempting to delete file C:\Windows\Installer\83e179.msp
MSI (s) (68:D4) [10:18:10:271]: MainEngineThread is returning 1603
MSI (s) (68:3C) [10:18:10:271]: No System Restore sequence number for this installation.
Schwerwiegender Fehler bei der Installation.
C:\Windows\Installer\8e88a.msi
Bei mir kommt der Verdacht auf, dass es etwas mit dem "MsiPatchOldAssemblyName" zu tun hat. Im AU1 wurden Files die im GAC liegen, erneuert, im AU2 hingegen werden keine GAC-Files erneuert.
Bin dankbar für jede Hilfe.
