Best Answer ur00361883 , 24 April 2015 - 12:51
Not like traditional databases, In MSI file we can't update a primary key with update query.In CreateFolder table, both Directory_ and Component_ are primary keys.
Posted 22 April 2015 - 08:18
When I am trying to use the below query to update CreateFolder table, then I am getting runtime exception
value= "somecomponentname";
database.Execute("Update `CreateFolder` Set `CreateFolder`.`Component_` = '" + value + "'");
I tried the similar command in vbscript also along with c# but not working.
But the updation is working fine if I try in other tables like Registry,Property
Please help me on this.
Posted 22 April 2015 - 16:27
I have no direct experience with this specific table but I did use database calls to modify a ListBox control at runtime. It required to make edits the the ListBox table at runtime. In developing this, I was only able to find code examples for a ComboBox. I had to convert that code for my specific case. I say this because I had one stumbling box when doing this. I didn't get the number of properties per entry correct. If you are using code that worked on one table but not another, check to make sure you are setting the correct number of properties for the table you want to edit.
The code I had wrong was:
hDatabase = MsiGetActiveDatabase(hMSI);
sQuery = "SELECT * FROM ComboBox WHERE Property='COMBOBOXPROP'";
// Open view into ComboBox Table
nResult = MsiDatabaseOpenView(hDatabase, sQuery, hCBOView);
// Allocate space to hold the properties of a combobox row...
hRec = MsiCreateRecord(4); <--------- this was set to 3 which caused me to have problems.
The number had to match the number of columns in the table
In your case, you need to set 2 properties.
In your code example, I only see one.
Posted 24 April 2015 - 12:51 Best Answer
Posted 24 April 2015 - 12:53
So, the approach I followed now is to read the complete row and delete it and create again with new value of Component_.
