set obj=GetObject("MyObject");
if !IsEmpty(obj) then
obj.MyProcedure ....
I didn't find a similar function in IS7. What can I do ?
Posted 24 January 2002 - 09:43
Posted 24 January 2002 - 22:39
There is a zip file located:
http://www.installsite.org/files/GetObject.zip
The description says that it should work with IS7, although I haven't looked into it yet.
Good Luck
Kurt Schneider
Posted 25 January 2002 - 16:11
In IS6 I used the IS-Object functionality to write my own objects with my own functions. Then, I included these objects (IDE: "Insert Installshield-Object...." ) into any IS project to use the functionality of these objects.
Now, when upgrading these projects (which contain my IS-Objects), this functionality is (???) no longer supported and my objects are not "transferred" into the upgraded project.
If this is no longer supported in IS7, I'm looking for a substitute for my old objects. Perhaps I can convert them to a merge module an call these functions over a CustomerAction... I'm still checking this, but this might by the only possible way.
Does anybody have any experiences with upgrading IS6-objects (with several functions included) to IS7?
