I'm having trouble getting the progress bar fill all the way up during my install. It fills to about 40 percent during the file copy process, then stops. My install completes OK, but the progress never advances past about 40%. This only seems to be a problem when I use Custom Actions in the execute sequence. If I select a simple feature that calls no CA's in the execute sequence, then the bar fills to 100% as expected.
Does Windows Installer add some default tick count for my CA's, and are my CA's required to post progess to it? If so, how? I'm using mostly defered execution CA's (some with a cooresponding immediate CA to setup the CustomActionData). Some are coded in either InstallScript, and others in "C" in a .DLL.
Any info on the Progress Bar tick count will be usefull - I can't find much documentation.
