I need to install conditionally a component.
After testing in the script if it should be installed, which code will install this particular component?
Thanks in advance for the suggestions,
Tamosai
Posted 04 October 2001 - 13:20
Tamosai
Posted 08 October 2001 - 07:56
The function you suggested solved the problem.
Just to share the information with others that might need this in the future, the command I used was:
if szSetupTypewd = "word97" then;
ComponentSelectItem( MEDIA, "DOT file", TRUE );
Vielen Dank Stefan,
Tamosai
