Posted 02 May 2002 - 15:46
Hi Rajesh,
You may use the following code for DSN validation on the next button of your DSN screen.
#include "stdafx.h"
#include "DSN.H"
UINT __stdcall CheckDSN(char *szServerName, char *szDatabaseName, char *szUserName, char *szPassword)
CString strServerName, strDatabaseName, strUserName,strPassword, strConnectString;
HWND hwnd = GetForegroundWindow();
strServerName = szServerName;
strDatabaseName = szDatabaseName;
strUserName = szUserName;
strPassword = szPassword;
strServerName.TrimLeft();
strServerName.TrimRight();
strDatabaseName.TrimLeft();
strDatabaseName.TrimRight();
strUserName.TrimLeft();
strUserName.TrimRight();
//strConnectString.Format("DRIVER=%s;Server=%s;Database=%s;UID=%s;PWD=%s;Network=DBMSSOCN;", "{SQL Server}", strServerName, strDatabaseName, strUserName, strPassword);
strConnectString.Format("DRIVER=%s;Server=%s;Database=%s;Trusted_Connection=Yes;Network=DBMSSOCN;", "{SQL Server}", strServerName, strDatabaseName);
CDatabase db;
try
if(db.OpenEx( strConnectString,CDatabase::openReadOnly |CDatabase::noOdbcDialog ))
return 0;
else
return -1;
catch(CDBException* e)
MessageBox(hwnd,e->m_strError,"ODBC Error",MB_OK);
e->Delete();
return -1;
// return 0;
You may then set properties in the ODBC checklist like
Database = [ControlNameForDatabase]
Server = [ControlNameForServer]
You may also use the following code for creating DSN programatically.
Private Declare Function SQLConfigDataSource Lib "odbccp32.dll" ( _
ByVal hwndParent As Long, _
ByVal fRequest As Integer, _
ByVal lpszDriver As String, _
ByVal lpszAttributes As String _
) As Long
Private Declare Function RegCloseKey Lib "advapi32" ( _
ByVal hKey As Long _
) As Long
Private Declare Function RegQueryValueEx Lib "advapi32" Alias "RegQueryValueExA" ( _
ByVal hKey As Long, _
ByVal lpValueName As String, _
ByVal lpReserved As Long, _
ByRef lpType As Long, _
ByVal lpData As String, _
ByRef lpcbData As Long _
) As Long
Private Declare Function RegOpenKeyEx Lib "advapi32.dll" Alias "RegOpenKeyExA" ( _
ByVal lpSubKey As String, _
ByVal Reserved As Long, _
ByVal samDesired As Long, _
phkResult As Long _
) As Long
Private Const REG_BINARY& = 3 ' Free form binary
Private Const REG_SZ& = 1 ' Unicode null terminated string
Private Const HKEY_CURRENT_USER& = &H80000001
Private Const HKEY_LOCAL_MACHINE& = &H80000002
Private Const KEY_ALL_ACCESS& = &H2003F
Public Enum ACTION
ODBC_ADD_DSN& = 1 ' Add User data source
ODBC_CONFIGURE_DSN& = 2 ' Configure existing DSN
ODBC_REMOVE_DSN& = 3 ' Delete data source
'ODBC Version 2.5 & higher
ODBC_ADD_SYS_DSN& = 4 ' Add system data source
ODBC_CONFIG_SYS_DSN& = 5 ' Modify an existing system data source
ODBC_REMOVE_SYS_DSN = 6 ' Remove an existing system data source
'ODBC Version 3.0
ODBC_REMOVE_DEFAULT_DSN& = 7 ' Remove the default data source. Experienced users only!
End Enum
Public Enum DSNTypeEnum
UserDSN& = 0
SystemDSN& = 1
End Enum
Private Const mc_DataFileNotFoundError As Long = 1001
Private Const mc_DataFileExistsError As Long = 1002
Private Type ErrorType
ETNumber As Long
ETDescription As String
ETSource As String
End Type
Private m_Error As ErrorType
Private m_ODBC_DSN_Name As String
Private m_ODBC_Driver_Name As String
Private m_ODBC_Data_Source As String
Public Property Let ODBC_DSN_NAME(ByVal sName As String)
m_ODBC_DSN_Name = sName
End Property
Public Property Let ODBC_DRIVER_NAME(ByVal sDriver As String)
m_ODBC_Driver_Name = sDriver
End Property
Public Property Let ODBC_DATA_SOURCE(ByVal sDBFile As String)
m_ODBC_Data_Source = sDBFile
End Property
Friend Function ExecuteDSNCommand( _
ByVal dsnType As DSNTypeEnum, _
ByVal sDSN_Name As String, _
ByVal sDriver As String, _
ByVal sDBFile As String, _
ByVal eAction As ACTION _
) As Boolean
On Error GoTo ExecuteDSNCommandError
Const PROCEDURENAME As String = "ExecuteDSNCommand"
Dim sAttributes As String
Dim sDBQ As String
Dim sMessage As String
Dim lRetVal As Long
Dim lErrNo As Long
If sDSN_Name = "" Then
sDSN_Name = m_ODBC_DSN_Name
End If
If sDriver = "" Then
sDriver = m_ODBC_Driver_Name
End If
If sDBFile = "" Then
sDBFile = m_ODBC_Data_Source
End If
sDBQ = mf_DSNRegistryEntry(dsnType, sDSN_Name)
If (sDBQ = "" And (eAction = ODBC_ADD_DSN Or eAction = ODBC_ADD_SYS_DSN)) _
Or _
(sDBQ <> "" And (eAction = ODBC_REMOVE_DSN Or eAction = ODBC_CONFIGURE_DSN _
Or eAction = ODBC_CONFIG_SYS_DSN Or eAction = ODBC_REMOVE_SYS_DSN)) Then
If Len(Dir(sDBFile)) = 0 Then
Err.Raise mc_DataFileNotFoundError, PROCEDURENAME, "Data file doesn't exist!"
Else
sAttributes = "DSN=" & sDSN_Name & vbNullChar & "DBQ=" & sDBFile & vbNullChar
lRetVal = SQLConfigDataSource(0&, eAction, sDriver, sAttributes)
End If
Else
If eAction = ODBC_ADD_DSN Or _
eAction = ODBC_ADD_SYS_DSN Then
sMessage = " already exists!"
lErrNo = mc_DataFileExistsError
Else
sMessage = " doesn't exist!"
lErrNo = mc_DataFileNotFoundError
End If
Err.Raise mc_DataFileExistsError, PROCEDURENAME, "DSN: " & sDSN_Name & sMessage
End If
ExecuteDSNCommand = True
ExecuteDSNCommandExit:
Exit Function
ExecuteDSNCommandError:
ExecuteDSNCommand = False
With m_Error
.ETDescription = Err.Description
.ETNumber = Err.Number
.ETSource = Err.Source
End With
Resume ExecuteDSNCommandExit
End Function
Public Sub CreateDSN( _
Optional ByVal dsnType As DSNTypeEnum = UserDSN, _
Optional ByVal sDSN_Name As String = "", _
Optional ByVal sDriver As String = "", _
Optional ByVal sDataSource As String = "" _
Dim eAction As ACTION
If dsnType = SystemDSN Then
Else
End If
If Not ExecuteDSNCommand(dsnType, sDSN_Name, sDriver, sDataSource, eAction) Then
With m_Error
If .ETNumber <> 0 Then
Err.Raise .ETNumber, .ETSource, .ETDescription
End If
End With
End If
End Sub
Public Sub DeleteDSN( _
Else
End If
With m_Error
End If
End With
End If
End Sub
Public Sub ConfigureDSN( _
Else
End If
With m_Error
End If
End With
End If
End Sub
Private Function mf_DSNRegistryEntry( _
DSN_TYPE As DSNTypeEnum, _
sDSN As String _
) As String
Dim lHKEY As Long
Dim sDBQ As String
Dim hKey As Long
Dim sRegValue As String
Dim lValueType As Long
mf_DSNRegistryEntry = ""
If DSN_TYPE = SystemDSN Then
lHKEY = HKEY_LOCAL_MACHINE
ElseIf DSN_TYPE = UserDSN Then
lHKEY = HKEY_CURRENT_USER
End If
If RegOpenKeyEx(lHKEY, _
"Software\ODBC\ODBC.INI\" & sDSN, _
0, _
KEY_ALL_ACCESS, hKey _
) = 0 Then
sRegValue = String(1024, 0)
If RegQueryValueEx(hKey, _
"DBQ", _
0, _
lValueType, _
sRegValue, _
Len(sRegValue) _
) = 0 Then
If lValueType = REG_SZ Then
sDBQ = Left(sRegValue, InStr(sRegValue, vbNullChar) - 1)
End If
End If
RegCloseKey hKey
mf_DSNRegistryEntry = sDBQ
End If
End Function
Gunavelu
