Error C9001
Partha Das
Partha Das
  • Members
  • 2 posts
Posted 06 February 2002 - 18:45
I need to know how I can use the following InstallShield library function :-
DeinstallSetReference (szReferenceFile);
InstallShield for MS-VC++ 6.0 is giving error when we try to compile(Error code: C9001) a script having this function call. Usually if something is not supported in InstallShield the help clearly says that it is not supported. But here the help doesn't say anything regarding not supporting this function. So if there is some way to use this function please let me know
Posted 09 February 2002 - 09:36
#Moderation Mode
MSVC++ comes with a limited edition of InstallShield Professional 5, so I'm moving this to the IS5 group.
Moved here
Posted 09 February 2002 - 09:37
I don't see this listed as unsupported, too. However if you get a compile error (which text did the error message display?), I guess it is unsupported in the VC++ edition. It works in the full edition.
