"ERROR 1500. Another Installation is in progress. You must complete that installation before continuing with this one."
Please help!!!!!!
Posted 19 January 2002 - 02:53
Please help!!!!!!
Posted 19 January 2002 - 18:41
Wrong forum. Moving to Windows Installer Runtime Errors.
Posted 19 January 2002 - 18:42
In addition (or alternatively) you could use the MsiZap tool from Microsoft to remove the remainders of the installation from registry.
Posted 05 February 2002 - 01:21
Any attempt to uninstall or install any program results in a 1500 error and so we can't install the microsoft zap utility and it can't be run without being installed apparently (how's that for good planning? :)
I've been looking for a solution for a week and nothing found so far.
If anyone knows what is responsible for launching the windows installer other than the two registry keys:
HKEY_LOCAL_MACHINE ->SOFTWARE ->Microsoft ->Windows ->CurrentVersion ->Installer ->InProgress
or the
HKEY_LOCAL_MACHINE ->SOFTWARE ->Microsoft ->Windows ->CurrentVersion ->RunOnce
registry areas I would love to know about it.
- John
Posted 06 February 2002 - 04:14
I've found that if you disable the MSI service (in the MMC), and then clear the InProgress key and RunOnce keys, AND then reboot, you're able to install the MSICleanup utility. MsiCleanUp is then able to clear out the installation.
Disabling MSI should prevent that early MSI process from starting.
Posted 06 February 2002 - 04:59
Used msconfig utility to prevent registry from loading, then was able to uninstall {our software} and to install version 2 of msiexec.exe (microsoft), and current version of iiscript.msi (installation wizard - 3rd party).
