Regarding the installation: Do I have to install WSH with the "scr55en.exe"? Are Merge Modules available?
Does there exist a silent mode for the scr55en.exe installation.
Any help is highly appreciated
Andreas
Posted 18 April 2001 - 14:41
Andreas
Posted 18 April 2001 - 18:20
You can run scr55en.exe even if WSH is already there. This is probably the safest method.
AFAIK there's no merge module for WSH.
Use /q to run in silent mode, and /r:n to suppress the reboot.
Posted 24 April 2001 - 06:37
however I encountered a problem trying to install scr55en.exe under NT 4.0: Error registering OCX wshom.ocx!!!
Using scripten.exe (with is for W2K only) I didn't have this problem.
Do you know if I can use sripten.exe with NT 4.0??
Andreas
Posted 26 April 2001 - 11:06
