I had came across this error also.
It might be of use to know that I asked Microsoft for the SQLBASE.MSM referred to in their KB Article Q274224
With this Merge Module, the error went away.
Posted 23 April 2001 - 18:13
Posted 01 October 2001 - 18:32
Is it possible for you to mail me this fix?
I have the same problem!
Thanking you in anticipation
Regards,
Thomas Eskesen
Posted 08 October 2001 - 10:59
Sorry for the delay but I was away.
Even after using the merge module that I talked, I still found lots of random problems when installing to different machines. So I decided not to use the Merge modules and instead I tell my customers to install MSDE using the setup provided with the SQL2000 CD.
So unfortunately, I no longer have the Merge module.
However, I heard that SQL2000 SP2 comes with all the updated merge modules.
You might find them there.
Hope this helps.
