I'm checking out the Eval version of the DemoShield and I'm trying to launch an HTML file from the source/installation CD.
I've attached a file showing the dialogs to set up reading a reg entry for Internet Explorer and Launching an Application with the .htm file as the command line arguement.
Let me know if this should work, because I can't get it to function properly. I don't know if it doesn't recognize the <CD> parameter on the command line arguement, or what???
Any help is greatly appreciated.
THANKS!
Launch .html file from CD
Superfreak3
, Mar 01 2004 22:52
Posted 15 March 2004 - 22:55
well, I've never used DemoShield, but since no one has replied for a few days I'll give a shot.
On your document I noticed that the line where you try to launch the .html documnet is : <CD>install.htm<CD>
if it's supposed to xml notation it would be <CD>install.htm</CD>
or is you're giving a path define it would be <CD>/install.htm (where <CD> is a system or program understood variable.
HTH
HTH
