I have something weird going on with a Major Upgrade. We've just switched back to InstallShield (2010) from Wise and we are ripping out our old application.
We are set in InstallShield to completely remove old first. Everything appears to go OK, but on initial launch, we get the repair. After further investigation, there is a component that should be installed, but it is not for some reason.
It is part of a feature that is installed and there are not conditions on it. There is a Custom Action that calls it, but it has a condition of $ComponentName=3. This action is set as Asynch, no wait so I don't know if its not set to install so the action doesn't run or if the Asynch, no wait setting just passes any errors if the file is not there when called.
What are some other reasons why this file may not be installed. I then tried just a fresh install without the major upgrade. When we install the latest version, the file in question is installed. Could it be getting confused with something still hanging form the version that was ripped out. I check the directory and it does get cleaned out so it shouldn't be a problem.
Any help is greatly appreciated!
Thanks!
UPDATE: If I mark the component's key file property to always overwrite, it seems to work OK following Major Upgrade. The .exe is installed then with the latest version. This is a little widget that rarely changes and has the same version across releases of our application. Something must be hanging from the old app somewhere, right?
Edited by Superfreak3, 07 February 2011 - 17:24.
