Hello Nilesh,
we have doene it with IS-Script:
Short and fast: Use old WindowsAPI.
// Function: SYS_Get_Local_EnvironmentVariable
// Purpose:
function SYS_Get_Local_EnvironmentVariable( sEnvVar, sEnvValue )
NUMBER nResult;
begin
nResult = KERNEL32.GetEnvironmentVariable(sEnvVar, sEnvValue, 1024);
return 0;
end;
// Function: SYS_Set_Local_EnvironmentVariable
// Purpose:
function SYS_Set_Local_EnvironmentVariable( sEnvVar, sEnvValue )
STRING sEnv;
POINTER pEnv, pResult;
BOOL bRe;
begin
bRe = KERNEL32.SetEnvironmentVariable(sEnvVar, sEnvValue);
if bRe then
sEnv = "Environment";
pEnv = &sEnv;
SendMessageTimeout( HWND_BROADCAST, WM_SETTINGCHANGE, 0, pEnv, SMTO_ABORTIFHUNG, cnSMTO_Timeout, pResult);
return 0;
endif;
return -1;
end;
// Function: SYS_Get_EnvironmentVariable
// Purpose:
function SYS_Get_EnvironmentVariable( sEnvVar, sEnvValue )
NUMBER nType, nSize;
NUMBER nResult, nReNr;
begin
// Initialize return value.
nReNr = 0;
RegDBSetDefaultRoot( HKEY_LOCAL_MACHINE );
nResult = RegDBKeyExist(csENV_KEY);
if nResult < 0 then
// Could not found key.
nReNr = -2;
else
nResult = RegDBGetKeyValueEx(csENV_KEY, sEnvVar, nType, sEnvValue, nSize);
if nResult < 0 then
// Could not get value. Or is empty.
nReNr = -1;
endif;
endif;
return nReNr;
end;
// Function: SYS_Set_EnvironmentVariable
// Purpose: The value can be empty.
function SYS_Set_EnvironmentVariable( sEnvVar, sEnvValue )
STRING sEnv;
begin
nReNr = -1;
RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE);
nResult = RegDBSetKeyValueEx(csENV_KEY, sEnvVar, REGDB_STRING, sEnvValue, -1);
if nResult = 0 then
pEnv = &sEnv;
nReNr = 0;
endif;
return nReNr;
end;
Declaration:
// Environment variables:
#define WM_SETTINGCHANGE 0x001A
#define WM_WININICHANGE 0x001A
#define HWND_BROADCAST 0xffff
#define csENV_KEY "SYSTEM\\CurrentControlSet\\Control\\Session Manager\\Environment"
prototype BOOL KERNEL32.SetEnvironmentVariable(BYVAL STRING, BYVAL STRING);
#define SMTO_ABORTIFHUNG 0x0002
#define SMTO_BLOCK 0x0001
#define SMTO_NORMAL 0x0000
#define SMTO_NOTIMEOUTIFNOTHUNG 0x0008
#define SMTO_ERRORONEXIT 0x0020
#define cnSMTO_Timeout 1000
prototype INT User32.SendMessageTimeout( HWND, LONG, LONG, LONG, LONG, LONG, INT);
I hope this helps.
André
