some more lines of the log:
******* Action: INSTALL
******* CommandLine: INSTALLDIR="C:\Program Files\Pointsec\Pointsec File Encryption\" TARGET
DIR="d:\" COMPANYNAME="Pointsec" USERNAME="Administrator" CLIENTPROCESSID="162" CLIENTUILEVEL="0" CURRENTDIRECTORY="D:\PMT\Pointsec_Common\File Encryption\20011002" SOURCEDIR="d:\zipbak\temp\_is99\" ACTION="INSTALL" EXECUTEACTION="INSTALL" ISSCRIPTRUNNING
="1" ROOTDRIVE="d:\" ALLUSERS="1" SECONDSEQUENCE="1" ADDLOCAL=DefaultProgram,UpdateDLL %HOMEPATH="\" %HOMEDRIVE="C:"
MSI (s) (8D:B2): No info for thread 1B2
MSI (s) (8D:B2): Searching for item Products\(NULL) in per-user managed key
MSI (s) (8D:B2): Did not find item Products\(NULL)
MSI (s) (8D:B2): Searching for item Products\(NULL) in per-user non-managed key
MSI (s) (8D:B2): Searching for item Products\(NULL) in per-machine key
MSI (s) (8D:B2): Found item Products\(NULL)
MSI (s) (8D:B2): Setting info for thread 1B2, in index 5
MSI (s) (8D:B2): Searching for item Products\8E1475B0E65DA4D4BAD1202037EE1E31 in per-user managed key
MSI (s) (8D:B2): Searching for item Products\8E1475B0E65DA4D4BAD1202037EE1E31 in per-user non-managed key
MSI (s) (8D:B2): Searching for item Products\8E1475B0E65DA4D4BAD1202037EE1E31 in per-machine key
MSI (s) (8D:B2): Found item Products\8E1475B0E65DA4D4BAD1202037EE1E31
MSI (s) (8D:B2): Getting info for thread 1B2, from index 5
MSI (s) (8D:B2): Setting info for thread 1B2, in existing index 5
MSI (s) (8D:B2): Searching for item Products\D15BD811CA4B60949AD47D5C3F341E4A in per-user managed key
MSI (s) (8D:B2): Searching for item Products\D15BD811CA4B60949AD47D5C3F341E4A in per-user non-managed key
MSI (s) (8D:B2): Searching for item Products\D15BD811CA4B60949AD47D5C3F341E4A in per-machine key
MSI (s) (8D:B2): Found item Products\D15BD811CA4B60949AD47D5C3F341E4A
MSI (s) (8D:B2): Removing info for thread 1B2, from index 5
MSI (s) (8D:B2): Note: 1: 2318 2: d:\zipbak\temp\_is99\Pointsec File Encryption.msi
MSI (s) (8D:B2): MainEngineThread is returning 1603
MSI
