My installer needs to redistribute the .NET framework, but I don't want to have a setup.exe wrapper so I've written a Custom Action to launch the web installer for .NET if the end-users machine does not already have it. This works perfectly fine with .NET 4.0 and .NET 3.5 but for .NET 4.5 the .NET installer reports "waiting for another install to complete" and fails - this error msg would be correct if my Custom Action was in the Exec sequence, but I specifically placed it very early in the UI sequence to allow for a nested installation.
The exact same InstallShield configuration/code works fine with .NET 3.5 and .NET 4.0 but fails with .NET 4.5, I'm using the standard web installer from Microsoft:
http://www.microsoft...s.aspx?id=30653
Does anyone know of any solution or workaround to this problem ?
Here's the code for my Custom Action:
if ( hasDotNET45 = FALSE ) then
MessageBox( "Missing .NET 4.5 framework!", INFORMATION );
LAAW_SHELLEXECUTEVERB = "runas";
LaunchApplication( szSupportDir^"\\dotNetFx45_Full_setup.exe", "", "", SW_SHOWNORMAL, 100000, LAAW_OPTION_USE_SHELLEXECUTE | LAAW_OPTION_WAIT_INCL_CHILD );
Delay( 333 );
endif;
