I have a very peculiar problem. Our product uses Installshield MSI project to deploy and we released the first version recently. We have an automated build system that uses ISStandalone Build system and this runs on a particular machine. The setup for the first version was created on this very computer. Now we have another version which is an upgarde and the setup that is created form this machine does not upgarde successfully. On the target machine it does identify the existing install and then runs an upgarde but none of the files are replaced and the new shortcuts are not created. I create the setup from a different machine with the same set of files using ISStandalone system and there is no issues with the upgrade. Any idea on what is going on. Any help greatly appreciated.
On more research I saw these messages in the installlog
MSI (s) (74:8C) [16:37:14:711]: SELMGR: ComponentId '{486B8E57-707E-9CEA-9F5D-01E0CBF294B2}' is registered to feature 'Application', but is not present in the Component table. Removal of components from a feature is not supported!
MSI (s) (74:8C) [16:37:14:711]: SELMGR: Removal of a component from a feature is not supported
The problem is that I do not have anything in the project with this component ID. I do dynamic linking of files in the component application but all of them seems to be fine as per the installlog.
--B
Edited by bijuishere, 13 July 2007 - 00:59.
