Is there a way to do that ?
Thanks for your help
Lionel
Posted 13 June 2001 - 09:07
Lionel
Posted 20 June 2001 - 21:03
ParentFeature
- ChildFeature
If you have the child feature set to required and the parent feature install level is higher than the default install level both will appear as unselected in the CustomSetup dialog, and when you go to select the parent the child will automatically be selected one other thing if you select the child feature then the parent will also be selected. Plus you will not be able to unselect the ChildFeature.
I hope this makes sence and is helpful.
TDG
